Dudley Turbo 88
Ruathatu
Dudley Turbo 88
by Ruathatu » Thu Dec 16, 2010 9:54 pm
the flush works ok but the fill is soooooooo slow, could anyone give a suggestion or two as to why this is so ??
Many thanks
by stoneyboy » Sun Dec 19, 2010 6:32 pm
Ruathatu,
Nothing to do with the dudley siphon its the ball valve causing the problem. Check the ball valve - see if it's partially blocked, if it's got the correct nozzle in it, if flow to the valve is OK.
It is currently Tue Jan 28, 2025 11:35 pm
