Hit Metal after Plasterboad
wizzywas
by wizzywas » Sun Dec 19, 2010 12:31 am
Hi All,
Hope someone can help.
I am fixing a set of 4 Ikea mirrors to my 1st floor hallway using redidriva fitting. I got to my final mirror and final fitting and the redidriva hit something solid after getting past the plasterboard. it does seem like metal behind the plasterboard.
Is there anyway I can drill through the metal and insert a standard screw in? as it would be possible to insert screw elsewhere.
got very annoying seeing that it was the last fitting I needed.
Thanks in advance
by stoneyboy » Tue Dec 21, 2010 2:46 pm
wizzywas,
"Is there anyway I can drill through the metal and insert a standard screw in". If it is a metal conduit with mains cables in it then not recommended.
wizzywas
by wizzywas » Tue Dec 21, 2010 11:41 pm
I dont think it is, How can I be sure, it could possibly be a metal frame.
stoneyboy wrote:wizzywas,
by stoneyboy » Wed Dec 22, 2010 12:53 pm
wizzywas,
Can only suggest you cut a small hole in the plasterboard so you can see what you are hitting. Cut the hole like a shallow taper cone which you will them be able to stick back in place using tetrion/pollyfilla.
wizzywas
by wizzywas » Wed Dec 22, 2010 9:45 pm
Thanks I might just give that a try.
It is currently Mon Dec 23, 2024 5:36 am
