Wall Odour - will Zinsser Bin fix it?
9 posts   •   Page 1 of 1
popsicle
by popsicle » Tue Dec 21, 2010 10:06 am
I have wall odour from using Crown Breatheasy paint and despite using the Crown sealer and repainting (twice!) the smell is still there. I was wondering if Zinsser Bin would be able to totally block the smell and also is there a lingering smell after using it and how long does it last.
Thank you so much in advance.
by stoneyboy » Wed Dec 22, 2010 1:06 pm
popsicle,
Yes ZB should seal in the smell completely.
popsicle
by popsicle » Thu Apr 21, 2011 1:32 pm
It didn't work :(
Any other ideas are most welcome
popsicle
by popsicle » Sat Jun 25, 2011 8:57 am
Just thought I'd do a quick and depressing update for anyone interested as it seems there are alot of other people also affected by this problem.
After finding out that shellac primer is the best odour blocker (which I'd already tried) and at one point the wall odour smell was coming through the ceiling to the room below, I decided I had no choice but to get that damn paint off the walls completely.
After stripping the paint off, the smell was horrendous. The smell hadnt just been going out into the room it was also going back into the plasterboard. After a few days the smell started to fade but three weeks later there is still the smell of wall odour especially when the weather changes. It is much fainter than before but it's still there (The wall odour has been there for a year though) . I don't know whether it will go away completely with time or if an odour blocker would completely seal it now. Personally, I never want to use any paint again. I believe that paint companies haven't got a clue about wall odour and how to deal with it. The paint research association wouldn't reply to my emails and have taken down their wall odour page and its obvious alkali resistant sealer doesnt work in all cases.
I'll stop there before I start ranting :(
I'll update when any changes happen.
by stoneyboy » Sun Jun 26, 2011 3:54 pm
popsicle,
Have you checked whether the wall is damp?
Many years ago I caught a plasterer I had employed peeing in the mix - he assured me that this accelerated the setting of the plaster ... I didn't use him again!!
popsicle
by popsicle » Mon Jun 27, 2011 2:43 pm
The wall is dry and I havent put anything on it since removing the paint. I also have the windows open during the day whenever I'm in, which is alot.
And....eurgh!!! Peeing in the mix?? That's a weird one lol.
popsicle
by popsicle » Mon Jun 27, 2011 6:35 pm
Oops, I forgot to mention that I stripped the paint off with a scraper so havent used any chemicals/liquids on it either.
by stoneyboy » Mon Jun 27, 2011 10:14 pm
popsicle,
Have you used a damp meter over the wall to check it is dry?
popsicle
by popsicle » Thu Jun 30, 2011 5:33 am
Just used a damp meter and its all ok.
It is currently Tue Jan 07, 2025 8:05 pm
