by plumbbob »
Fri Dec 24, 2010 5:06 pm
Oh dear now this is complicated!
Firstly, there is no obligation I am aware of that will force any "authority" to make good the installation. This doesn't even happen with gas. Not even if it is deemed dangerous and the installer incompetent. All that happens is Network Gas will disconnect the supply leaving it to you to sort out. Water supplies cannot even be disconnected simply for health reasons so expect even less interest from them.
If the original installer was WRAS approved, in theory he could be taken to task if it is decided his work did not comply with regulation but realistically as a sub-contractor, deciding who was responsible for what could be challenging to say the least and that won't get the job fixed anyway.
Now if the plumber was not WRAS approved then it gets tricky because you as the householder are responsible for any non compliance and action by the water company could be taken against you personally.
Now even worse. The above paragraph is possibly not entirely correct because strictly speaking as the supply goes through your neighbours land, it is actually their responsibility to ensure compliance not yours.
Of course if you take this up vigorously with him, you may wake up the following morning to find the bit of your blue supply pipe which went over his land is now in his wheelie bin! Believe me. It has been done which is why water companies will not approve supplies over other private property.
To be honest, I guess the buck is going to end up with you. Maybe your neighbour will be sympathetic and help, but I am not sure who else might.
