Ceiling damage?
ellanvannin54
Ceiling damage?
by ellanvannin54 » Sat Jan 01, 2011 3:01 pm
I have had a serious leak from my water tank in the attic. The water leaked into the bedroom ceiling and living room ceiling down stairs. Can someone tell me if the plaster board ceiling need replacing even though they are now dry? I have been told that their itegrity is now compromised?
by stoneyboy » Sun Jan 02, 2011 10:10 pm
ellanvannin54,
If they've stayed in place their probably OK but use a straight edge to check for sagging.
JRS
by JRS » Sat Jan 15, 2011 10:24 pm
I would say yes, or maybe just cut out the affected area. Gyproc is like a sponge, soaking in the water. If it was a small amount of water then wait till its dry and undercoat the water mark then repaint.
chris_on_tour2002
by chris_on_tour2002 » Thu Jan 20, 2011 12:06 am
if it's still flat, not coming away and perfectly dry then it's probably OK.
you will most likely need to apply some kind of damp stain block such as Aquaseal to stop the damp patch from grinning thru your fresh paint - and it will without treatment regardless of how many coats you apply.
It is currently Fri Nov 22, 2024 3:18 pm
