JL washer dryer starts then stops fault
simonbagger
by simonbagger » Sun Jan 02, 2011 8:07 pm
I have a JLWD 1406 washer dryer which today has developed a fault, when switched on to wash after from a few seconds and upto a couple of minutes the machines start / pause button starts to flash and the machine stops what ever it is trying to do.
I then have to drain the water.
I am able to run the spin ok, dry ok but all of the wash cycles are the same.
Yes it is out of warranty, by a year, just my luck.
Have anyone any idea what it might be, door lock ?? programmer ??
SludgeIslandGrinch
Re: JL washer dryer starts then stops fault
by SludgeIslandGrinch » Sat Sep 17, 2011 12:50 am
Mine is doing exactly the same thing that you describe. Got someone coming to look at it. I'll let you know the outcome.
It is currently Fri Nov 22, 2024 9:43 pm
