Adjust Kitchen Cupboard Door
fairtry
by fairtry » Wed Jan 05, 2011 6:14 pm
Following the Cupboard Door Adjustment project from this site. Thanks - it's been a great help... BUT screws 2 & 4 (The ones that hold the hinge to the wall of the cupboard) do not tighten fully and hold the hinge well enough. How can I make the hole tighter again? Is there a filler or something I could use?
http://www.awin1.com/awclick.php?awinmid=1228&awinaffid=61071&p=http://www.screwfix.com/app/sfd/cat/pro.jsp?id=12202&ts=90492
by stoneyboy » Fri Jan 07, 2011 5:41 pm
fairtry,
Get some 2-part filler, mix a small quantity and fill the screw holes, refit the screws loosely before the filler sets, tighten them after the filler sets.
fairtry
by fairtry » Sat Jan 08, 2011 1:03 pm
stoneyboy wrote:fairtry,
Thanks very much stoneyboy. - cupboard only a couple of years old. I am keen to get this sorted - Can you recommend a suitable product?
oakie
by oakie » Sun Jan 09, 2011 7:52 pm
Any 2 pac filler from an automotive store will do,isopon etc.
And depending on your type of hinge,look at the middle of the hinge you may notice a fixing hole in the middle of the back plate.You can fix the hinge there also,using a 3.5x16 wood screw.
but you will no longer be able to adjust the door up and down
It is currently Sat Nov 23, 2024 9:06 am
