Had a problem with the wall mounted timer / programmer as the on / off lights would not switch off so it had to be on all the time.
To turn the heating and water off I had to manually turn the controller on the bolier to zero.
Tonight I took the cover of the timer / programmer, prodded (I know I shouldn't have) and put it back on and then when I moved the on / off buttons they were working fine again.
The problem now is that the 24hr clock dial is not turning.
Any help / comments would be appreciated before I call someone out.
