by wayne 78 »
Sun Jan 16, 2011 9:23 pm
[quote="sparx"]It may just be the larger bore of the bath tap & pipes is allowing a too high flow rate through the boilers heat exchanger, to prove try turning tap on fully then part closing it to slow the flow a bit. repost results[/quote] thanx for reply sparx. what you suggested did work the water got hotter when i part closed the tap. the thing is it use to be hot with the tap on full. and the temperature use to go to 70 now it stops at 60 oh well looks like its gona take longer to fill the bath from now on lol
