French doors into a load bearing wall - which lintel!!??
Ask questions and find answers on a range of subjects relating to self build projects
6 posts   •   Page 1 of 1
Spark180483
by Spark180483 » Thu Jan 13, 2011 7:51 pm
HELP!!! I am in the planning stage of installing french doors inbetween my lounge/dining rooms, i've planned everything so far apart from the important thing - which size/strength of lintel i should install...
The wall is a breeze block single skin wall which is two stories high (so there with be approx 3m of wall above the new lintel) the opening will be 1900 wide with lintel overlapping 150mm each side...
How do i work out which lintel will meet modern regs? thank you in advance if you help me out cheers mark (salisbury, wilts)
lintol
by welsh brickie » Fri Jan 14, 2011 1:04 pm
Go for CATNIC steel lintol standard size is 2400mm long 150mm deep x 100mm wide.
andy01
Re: French doors into a load bearing wall - which lintel!!??
by andy01 » Thu Sep 08, 2011 9:02 pm
get and SE to size it up
by welsh brickie » Fri Sep 09, 2011 7:29 am
the technical data for the catnic lintol load is available at the catnic website.I have never had any problems using CATNIC and the Building inspector has always passed the lintol,As you are at planning stage specifying the lintol and the load bearing,you do not require a structural engineer,an architect will confirm the data,And submit the plans for approval for the building inspector to confirm.
xavi99
by xavi99 » Sun Sep 11, 2011 8:43 pm
You need to ascertain the amount of load being transmitted down the wall. Does the wall support floor joists and roof load from struts?
This is something that a structural engineer could calculate or you could use the technical departments of Catnic or IG or Keystone who are all lintel manufacturers.
I am a little surprised by Welsh brickies comments that a building inspector usually accepts a Catnic because usually, in my experience, they tend to request calculations.
Alternatively you could approach a steel fabricator because they often carry there own structural engineer's who can size a steel beam and then supply and fix if required.
Good luck,
99
michael alan
by michael alan » Sat Aug 31, 2013 2:36 pm
ig or catnic both the same all the lintols they supply regardless of lenght are assumed to be structurally approved for that particular job and the bco`s assume that. no harm in cetting confirmation before you start though
It is currently Fri Nov 22, 2024 3:02 pm
