SHOWER WATER COMING OUT OF OVERFLOW PIPIE
10 posts   •   Page 1 of 1
KENNY G
by KENNY G » Sat Jan 15, 2011 2:46 pm
WHEN I TURN ON MY SHOWER THE WATER COMES OUT THE OVERFLOW PIPE. CAN YOU HELP PLEASE
plumbbob
by plumbbob » Sun Jan 16, 2011 9:44 am
Without knowing what type of shower you have I wouldn't even begin to know how to help!
KENNY G
by KENNY G » Sun Jan 16, 2011 12:36 pm
its a triton hawaii 2 electric shower.
by htg engineer » Sun Jan 16, 2011 5:10 pm
If it is a mixer type shower that is tank fed then it seems you have connected to mains cold water ? because the cold water pressure is greater this will backfill the tank - causing it to overflow.
The cold water must be tank fed also.
htg
KENNY G
by KENNY G » Sun Jan 16, 2011 5:43 pm
I do not have a tank as i have a combi boiler & it has always been on mains cold water & worked ok up to sat morning.
plumbbob
by plumbbob » Mon Jan 17, 2011 12:18 am
KENNY G wrote:its a triton hawaii 2 electric shower.
I presume you mean the water is coming from the small pipe behind where the shower hose is?
This is not an overflow but a pressure relief valve designed to protect the shower if the hose or head becomes blocked. When excess pressure is experienced, a small ball bearing is forced out allowing water to flow down the pipe
This part is supposedly non resettable so ought to be replaced. If however, you can find and replace the ball bearing it may be possible to avoid buying a new part. Of course, you need to address the cause of the over pressure in the first place.
by htg engineer » Mon Jan 17, 2011 9:54 pm
Well I was only guessing - with the limited info provided - lol
The type of shower helps - hopefully Plumbbob has solved it - still with limited info though.
What overflow/where is the overflow ?????
htg
shabir.fazal
Re: SHOWER WATER COMING OUT OF OVERFLOW PIPIE
by shabir.fazal » Sun Oct 25, 2020 10:46 am
Did you fix this problem?
I have the same shower Triton Hawaii 2 electric shower (8.5kW), fed from cold mains, no tank.
When turned on some water comes from the shower head but most comes from the pipe on the right of the hose. What i believe to be the pressure relief valve has some electric device in it with two wires connected to it. Is this the part i need to take off and replace?
Picture attached.
plumbbob
by plumbbob » Sun Oct 25, 2020 10:52 pm
shabir.fazal wrote: Is this the part i need to take off and replace?
Probably not. The part with "wires" is the low pressure sensor which stops the heating element form working if the input water pressure is too low.
The pressure relief valve is the transparent pipe protruding from the bottom of the casing just to the right of the outlet pipe.
shabir.fazal
by shabir.fazal » Tue Nov 03, 2020 10:55 am
The transparent pipe doesn't have a valve on it?
What could be the problem with this shower?
It is currently Wed Feb 05, 2025 6:36 am
