Bath tap problem
michaelwright
Bath tap problem
by michaelwright » Sun Jan 16, 2011 9:55 am
:D Hi, ...over the past few years the water from my hot tap in my bath has slowly dribbled to a stop!
Directly after the bath was fitted the water pressure was normal from hot tap.
Over a period of 3-5 years it has reduced to nothing, with one period lasting 2-3 months last year were water flow was again normal.
Now not even a drip!
All other taps in the flat are working well.
Can anybody help please? :o
by htg engineer » Mon Jan 17, 2011 9:56 pm
Probably just a washer, turn off water, drain tank if necessary, remove tap head/handle undo gland nut and remove - change washer and refit.
There could also be a plastic insert in the spout of the tap, this can sometimes become blocked - pop it out using a screwdriver and clean.
htg
michaelwright
by michaelwright » Tue Jan 18, 2011 7:33 pm
:lol: Thanks for the advice htg engineer, I have checked for the plasic insert and have not found one.
I will do as you advize and report back!
thanks
mike :wink:
It is currently Sun Jan 26, 2025 7:31 pm
