by SPUD1701 »
Fri Jan 21, 2011 10:14 pm
If you are proposing to built a timber wall to create a cavity then you will have to fit perp vents to outside brick between pointing to vent this sapce.
If you have not already tried, why not fit a dehumidistat extractor fan this will automatically come on when condensation in bathroom gets too high. Either fit trickle vent to window or brick vent through wall to oustide air to provide fresh air to replace what being removed by extractor and heat the room, by having these three things working this will reduce if not remove the condensation problem.
Hope this helps
