Asbestos Sheet Garage Roof and condensation/leaking
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
arthur49
by arthur49 » Wed Jan 19, 2011 12:15 pm
Don't really want to go to the extent of replacing the whole roof as asbestos sheets are intact and undamaged. However when its cold and wet roof suffers badly from condensation on the inside.
Tried Search facility but could see nothing.
I've tried bitumen paint on the screws/rubber grommets but the real problem is the sheets not the holes! Anybody any suggestions? Would a coat of bitumen all over the outside surface help?
Many thanks in anticipation
by stoneyboy » Wed Jan 19, 2011 10:24 pm
arthur49,
It's condensation and you won't stop it forming in cold weather.
Perry525
by Perry525 » Mon Jan 24, 2011 7:07 pm
When warm wet air meets your cold car, green house, garage, whatever, the water vapour in the air turns from an invisible gas into condensation, dew, frost.
The only ways to stop the water vapour entering your garage is to seal all the openings.
You need to fill all the gaps, cracks, holes with foam or other fillers.
andy01
by andy01 » Tue Feb 01, 2011 10:38 pm
where is the condensation coming from? if its created from inside the garage, ie your breath whilst working in there, then ventilation is required.
however if its just the air, then try sealing it to prevent more water vapour entering.
condensation
by welsh brickie » Wed Feb 02, 2011 9:13 am
Use sprayfoam on the inside of the roof that will solve all your problems
you can buy do it yourself kits.
It is currently Sun Dec 22, 2024 6:55 am
