shower pumps
paul thomas
shower pumps
by paul thomas » Wed Jan 19, 2011 2:11 pm
I recently installed a new shower pump (Grundfos Watermill) followed all the instructions to the letterand placed a flange from the hot warter supply, on switching the pump on it did not deliver pressure supply and is very noisy, as I only have a shower unit which is used a very lot I put the old one back into the system which works fairly well, I am informed br B&Q that I should contact the manufacturer who will talk me through the problems or they will send an engineer out, if I remove this new pump it negates my warranty!!!! as stated the shower is our only way of bathing, can anyone help?
chris_on_tour2002
by chris_on_tour2002 » Sat Jan 22, 2011 12:46 am
sounds like there's air in the pump - did you bleed it upon commissioning?
chris_on_tour2002
by chris_on_tour2002 » Sat Jan 22, 2011 12:47 am
and does it pump both hot and cold? does it have a dedicated supply from the CWSC?
It is currently Fri Jan 10, 2025 7:50 pm
