by dave6953 »
Fri Jan 28, 2011 11:06 am
[quote="ericmark"]One pair red and black to com at top and L1 at bottom.
Second pair com bottom L1 top.
L2's are not used. However if switch works wrong way changing from L1 to L2 will swap which way is off and on.
The earth to terminal on backing box if there is one. If not just tape up.[/quote]
hi ericmark,I tried what you said but it still does not work,the one light works,(the original one)but the new light will not work,what I did not mention was. The second light is an outside security light.thank you.
