block paving
flat432
block paving
by flat432 » Fri Feb 04, 2011 10:49 am
Can I lay brick block paving onto the existing patio slab paving
by stoneyboy » Sat Feb 05, 2011 5:27 pm
flat432,
Yes but you'll need a bed of 50-75mm sand under the blocks so it will raise the patio by 150mm. Don't forget you must fit edge restraints.
It is currently Sun Dec 22, 2024 12:52 pm
