Fixing to steel framed stud walls
harv
by harv » Mon Jun 18, 2007 10:06 am
I've been asked to fix a pair of moderately heavy loudspeakers (6-7 kg) to a steel framed stud wall in a school. Normally, in solid walls, I would use expansion bolts but obviously they would not be suitable here. Bearing in mind the location, safety is paramount. Any suggestions would be very welcome.
thedoctor
by thedoctor » Tue Jun 19, 2007 7:48 am
Use a timber to stick to the wall first. Use Gripfil adhesive (see our adhesives used at home project) as well as a Heavy Duty Redidrive plasterboard fixing (See our fixing to plasterboard project) in each corner of the timber also. Gripfil is a very strogn adhesive which will hold much heavier weights than thius and the fixings are simply to keep the board tight to teh wall and stop it slipping while the adhesive goes hard.
harv
by harv » Tue Jun 19, 2007 12:50 pm
Thanks very much for that. Do you think a 300mm square piece of 18mm MDF would be adequate as I have quite severe space constraints
It is currently Mon Jan 06, 2025 8:54 pm
