stand alone pir
gannet
stand alone pir
by gannet » Fri Feb 11, 2011 9:22 pm
hi there
will a mains stand alone pir activate a siren that i want to fit near my heating oil tank or would i have to step down to 12v /15v
regards peter
by ericmark » Sat Feb 12, 2011 3:54 pm
There are many different ways to wire and both extra low voltage and low voltage are both options. However there are rules on alarms sounding. Normally to comply with the rules one would need an alarm panel so that the sounder will switch off within required time etc.
Since most sounders have a 12 volt anti-tamper likely you will need to use a 12 volt system.
It is currently Thu Jan 16, 2025 12:10 am
