galvanised mains pipe
mjwnew
by mjwnew » Sun Feb 20, 2011 1:54 pm
i have galvanised feed pipes to my kitchen which have no independant stop cocks they convert to copper pipe to go to sink taps, can i use pipe freeze kit on galv pipe to fit stop cock on copper pipes
by stoneyboy » Mon Feb 21, 2011 6:17 pm
mjwnew,
Certainly the freeze kit will form a slug of ice in the pipes but whether they will remain in place is another matter - the inside of the pipe is likely to have a thick coating of rust and limescale (if you are in a hard water area) and this could be a nice lubricated weak point.
Turn off the mains in the road and look for a stopcock in the hot water system if necessary.
It is currently Fri Jan 10, 2025 8:27 pm
