Soil between the floor and wall
edm
by edm » Tue Feb 22, 2011 2:15 pm
I recently pulled up the tiles on my kitchen floor, underneath was concrete as expected, but when i removed the rotten skirting boards i discovered there is a 1-3 cm gap between the floor and the wall that seems to be filled with black soil. I dug down 2 inches and it was still soil.
How or what should i do about this gap
Should i just fill with concrete :?:
is this gap the cause of the damp in my kitchen :?:
Thanks ed
by stoneyboy » Tue Feb 22, 2011 9:00 pm
edm,
I suspect you are in an older property - probably one which used to have a dirt floor. Someone has laid a concrete slab but not bothered to remove the skirtings when laying the concrete.
You need to check for damp in the floor and see if a DPM has been installed, if not ignore it or dig up the floor and lay one incorporating a dpm.
edm
by edm » Fri Feb 25, 2011 10:13 am
Thanks for the reply and advice
cheers ed
It is currently Thu Dec 26, 2024 7:32 pm
