How To Fix My Bed??
madamesketch
How To Fix My Bed??
by madamesketch » Tue Feb 22, 2011 8:36 pm
Hi All,
Bought a brand new bed from eBay about 7 months ago.
It is metal with a metal frame around the edges and a metal support bar up the middle.
There are wooden slats that connect from the edges of the frame to the middle support bar. These slats slot in on both edges to plastic pockets with nipple things on them, and these nipple bits then pop into the holes on the metal frame and support bar.
The problem is these plastic bits are useless and split under the combined weight of me and my OH, which means that any slight movement such as turning over/sitting up in bed etc makes the wooden slats direcly underneath us fall out of the split plastic bits and go crashing to the ground! It makes a deafening crash and mattress then falls down the gap! We replaced the split plastic with the spares provided, but they just split again so we've just had to balance the slats in the split plastic and not move all night.
OH thinks the wooden slats are flimsy and a bit useless as well as plastic. he says they have bowed in the middle which isn't helping them to stay in the useless plastic bits.
I'm really fed up with it - I need my sleep!!
Does anyone know what we can do to fix this? Cant afford a new bed and even if we could, all of the ones I've seen seem to be put together the same way.
Mr Makeshift
by Mr Makeshift » Thu Feb 24, 2011 11:52 pm
Never buy a bed from ebay. Get one from a shop that u can test first.
(BTW not all beds are made the same, there are loads of different designs).
You've just got a cheap nasty one that's all.
It is currently Fri Nov 22, 2024 6:38 am
