Hot water in cistern
Sonny
by Sonny » Thu Feb 24, 2011 2:51 pm
I have an immersion heater and I'm getting hot water in my toilet cistern and through the cold tap in the bathroom. The cold water tap in the kitchen is ok. Any ideas?
Mr Makeshift
by Mr Makeshift » Thu Feb 24, 2011 11:31 pm
Yeah, someone has screwed up your plumbing! (Are u getting cold from the hot tap then?)
chris_on_tour2002
by chris_on_tour2002 » Sat Mar 19, 2011 2:37 am
is this a new installation or is this a problem that has recently started on an established system?
i don't wish to scare you but this may be serious - you need to get a professional in to look at it as you could have a potential lethal problem.
do you have a mains or gravity fed system? if gravity the thermostat may have gone on the hot water cylinder. is it making gurgling noises?
your cold water in the bathroom and toilet are probably fed from a cold water storage tank in the loft - check to see if this is the case and if so check the temperature of the water in the tank. is it warm or hot? it shouldn't be but if it is then it's almost certainly a faulty thermostat.
if the thermostaton your hot water cylinder fails it can cause the water inside to overheat and potentially boil. this will cause a rise in pressure in the cylinder that forces the hot water up through the vent pipe and into your cold water tank. if the problem persists and you have a plastic tank in the loft it could fail under the heat and burst, spilling gallons of very hot water into the room below.
there was a very sad and tragic case in the news not so long ago of a toddler that died in her bedroom when the tank in the loft above failed and she was scalded. made all the more tragic as the fault is so easy and inexpensive to fix.
i'm not saying that this is the fault in your case, it could something as simple as a hot water pipe contacting the cold feed to the toilet and bathroom and the heat is being transferred.
either way you need to take this seriously and get in a pro as soon as possible and until you've managed to isolate the fault you should turn hot water off.
no doubt you are wondering why then the cold water at the kitchen tap is not running hot. your cold water at the kitchen sink has to, by law, be fed directly from the incoming main as it is your drinking water. therefore the fault would not cause your kitchen cold to run hot.
It is currently Fri Nov 22, 2024 5:48 am
