Damp kitchen - Outer ground level is 4 inces higher?
yoshi_69
by yoshi_69 » Sat Feb 26, 2011 10:05 am
Hello,
My kitchen wall is damp and I have removed the plaster to try and dry it out but I have noticed that the ground level outside is 4 inches higher.
previous owner has injected damp proofing but this is from the outside and is 8 inches higher than the internal ground level.
The wall is solid brick (1 brick length thick)
Any advice on how I can rectify would be appreciated.
Also the kitchen is generally damp as we do not have any direct heating in the room and from cooking etc the plaster seems to bubble and is going mouldy. I am going to remove the plaster and use bourding and replaster and have central heating installed. Will this resolve the issue?
damp
by welsh brickie » Sat Feb 26, 2011 6:13 pm
rake out and repoint the brickwork internally up to at least 1 metre from the floor.then paint at least 3 coats of buitumin paint on the wall then you can dryline with insulated plasterboard.Also install a vent through the wall to create airflow.
It is currently Thu Dec 26, 2024 7:58 pm
