Glowworm Glide Down Mechanical Timer
currymuncher
by currymuncher » Sat Feb 26, 2011 11:50 am
My timer will only turn on and off manually and my room thermostat does not work either. Should I replace both or can I buy a programmable thermostat to do both saving me some money?
Glowworm 30cx Glide Down Mechanical Timer @ £48.00 and honeywell thermostat @£13
[/b]
by ericmark » Thu Mar 17, 2011 7:38 pm
The "Horstmann DRT2 Room Thermostat" does both time and temperature and instead of switching on and off it switches to a different temperature so you can set to 10 degs overnight and 20 degs in morning then drop to 18 degs for main part of day and back to 20 deg in evening for example.
If you also want hot water then you may need a timer for hot water but unless the storage tank is poorly lagged you may as well have water on 24/7.
Wiring will depend on system but the "Horstmann DRT2 Room Thermostat" has volt free change over contacts so will work with most systems.
Disadvantage is the two AAA batteries need changing once a year.
currymuncher
by currymuncher » Sat Mar 19, 2011 8:14 am
cheers mate I´ll look into it
It is currently Thu Jan 16, 2025 12:13 am
