Suspended Ceiling
6 posts   •   Page 1 of 1
cobre
Suspended Ceiling
by cobre » Sat Feb 26, 2011 2:59 pm
I have to install a secondary ceiling independent of the existing lathe and plaster ceiling to meet 60 minute fire regulations. The secondary ceiling will only support the weight of a double layer of 12.5 mm Soundbloc plasterboard and need to be completely independent of the existing ceiling . The maximum span is 3.8 metres at widest point and tapers to 2.8 mteresover a 9 metre length. Can anyone help with the joist size that would be required
cubleyboy
Re: Suspended Ceiling.
by cubleyboy » Mon Feb 28, 2011 11:01 pm
cobre wrote:I have to install a secondary ceiling independent of the existing lathe and plaster ceiling to meet 60 minute fire regulations. The secondary ceiling will only support the weight of a double layer of 12.5 mm Soundbloc plasterboard and need to be completely independent of the existing ceiling . The maximum span is 3.8 metres at widest point and tapers to 2.8 mteresover a 9 metre length. Can anyone help with the joist size that would be required
Hi Cobre, I would think the easiest and quickest way for you would be to fit a suspended metal frame ceiling. This will cover your fire regs with double boards. Best of all job done and skimmed in a couple of days!
Cubleyboy.
cobre
by cobre » Tue Mar 01, 2011 10:09 am
Hi Cubleboy Thanks for your response my main problem is the fact that the ew ceiling needs to be totally independent of the existing ceiling and as far as I know the metal system will require to be suspended off of the existing joists for a 3.8 M span
Cobre
chris_on_tour2002
by chris_on_tour2002 » Thu Mar 03, 2011 10:44 pm
cobre - is there a specific reason why it has to be independent of the existing ceiling?
cobre
by cobre » Sat Mar 05, 2011 3:18 pm
I have spoken to sound engineers and if the ceiling is attached to the existing ceiling it could transmit sound and may not pass the sound test.
I am also dropping this ceiling by 1 metre so have plenty of room for timber joists and I acn use my existing workers rather that a suspended ceiling company
andy01
by andy01 » Sun Mar 13, 2011 8:36 pm
find the building regs part a (structural) 1992 - not the current version, use to be on the planning portal
in the back are span tables
It is currently Sat Jan 25, 2025 5:28 pm
