Bypass valves
GARYF
Bypass valves
by GARYF » Mon Jun 18, 2007 9:45 pm
Can anybody advise me on the difference between a auto bypass valve and a adjustable differential bypass valve. At what point in the system are they fitted? My boiler has the pump fitted directly above with the 22mm flow and return pipes running parallel to each other, would this be a good place to install the valve??
Gary.
It is currently Sun Dec 22, 2024 7:35 pm
