Chocbox or Junction box
clarets
by clarets » Mon Feb 28, 2011 10:01 am
Looking for a little advice regarding the wiring from the ceiling rose to 5 new GU10 mains downlights. Ill be using the daisy chain method to wire up the new lights however, is it better to use a chocbox or junction box for the original rose wiring to the first downlight. If its a junction box, what amp should it be? Thanks for any advice.
collectors
by collectors » Tue Mar 01, 2011 8:01 am
Either can be used assuming you mean a chocbox is as per this link. Google "tlc-direct.co.uk/Products/CHOCBOX.html?source=froogle"
5amp minimum connectors should be used when using either method.
russell fields
Re: Chocbox or Junction box
by russell fields » Fri Nov 11, 2011 11:58 pm
remember all conections must be accesible
It is currently Mon Nov 25, 2024 7:14 am
