Cold Flat Roof No Ventilation Problem
rossbardon
by rossbardon » Sat Mar 05, 2011 8:29 pm
I have recently brought a property which has a old conservatory / extension at the back with a flat roof. I want to put up a new plasterboard ceiling in this room to replace the cardboard tiles which are on the ceiling. Upon removing the tiles I have found:
* Paper layer with one side film (looks like old radiator paper)?
* Wool Insulation maybe 100mm thick
* No ventilation!
The gap between the end of the joists and the decking is 155mm (top of slope) to 105mm bottom end (bottom of slope).
I now need to decide what is best to do.
1) Do I add vents into the soffits for ventilation? But due to the limited joist size I would probably need to forfeit having any insulation.
2) Or do I carry on with no ventilation and stuff it with insulation? (As it was already).
The roof is NOT in bad order considering its age and lack of ventilation but I would like to do what I can to improve its life span and reduce potential problems for myself in the future.
Advice gratefully welcomed!
insulating
by welsh brickie » Sat Mar 19, 2011 11:41 am
fix 75mm kingspan insulation boards tight in between the roofing joists.On the outside drill and fix soffit vents for ventilation and plasterboard the ceiling job done...
It is currently Mon Dec 02, 2024 12:54 pm
