Window shutters
semilha
Window shutters
by semilha » Mon Mar 07, 2011 9:48 am
Hi need to make some victorian window shutters all boxed in to look as if they where original .
Don't have the tools to do panels in pine.
was thinking of using plywood or MDF .they will be abou 24cm by180cm Hight .
Any advise appreciate thank you .
Perry525
by Perry525 » Tue Mar 08, 2011 8:15 pm
Use 9mm waterproof plywood on the outside and fix two inch thick polystyrene on the inside of the plywood covered with 6mm plywood.
Making a sandwich of plywood and polystyrene will give you good insulation and save a lot of money on cold nights.
Make sure they are a tight fit, to keep in the heat.
It is currently Tue Jan 28, 2025 10:11 pm
