by andy01 »
Tue Apr 12, 2011 1:56 pm
sorry i meant are the foundations capable of the job being asked of them?
ie if they are designed to supoport one storey what makes you believe they will support an additional storey? do you know the width of the foundation and the bearing capacity of the soil? or can you state it will be ok based on your own experiance?
if the walls of the garage are only one brick thick they probably wont be able to support the additional load of the structure above, due to flexural cracking rather than compression strength of the brick. i would expect the BCO would like to see some calcs for this.
tell your client to employ an engineer. let them lead the design, wall build up, interfacing of elements etc, and then you will know how to build the structure
if the timber frame is coming from a timber frame manufacturer they will not take responibilty for the garage walls, foundations, timber trusses, waterproofing etc.
can you clarify what exactly you are confused about?
