Difficulty getting watertight seals on Bath & Sink Waste
Cell01
by Cell01 » Wed Mar 09, 2011 11:19 am
This is driving me mad!
Installed new bath & sink - all gone fine apart from both leak from the plug holes. Have tightened as much as can without overtightening, have put more robust washers on, have tried adding sealant but still both leak.
What am I doing wrong?
Cheers,
by htg engineer » Wed Mar 09, 2011 7:16 pm
Hard to say without seeing, as long as you have the rubber washer or seal between the waste grate and the bath in the right place then it should be watertight.
If it's those cheap plastic waste grate - bin it. Buy a decent waste grate.
htg
chris_on_tour2002
by chris_on_tour2002 » Sat Mar 12, 2011 9:32 am
where exactly is it leaking from? have you tried plumbers mait?
It is currently Sun Dec 22, 2024 7:20 am
