Triton T70si fault
ItsBroken
Triton T70si fault
by ItsBroken » Thu Mar 10, 2011 6:55 pm
Hi Folks
We have the above shower but its started to play up...........
It will work fine for approx 5-10 mins then the water will stop flowing, power light stays on but no flow - pressure from taps is fine.
No fluctuations in the temp prior to the stop in flow.
Any ideas of the posssible cause would be greatful.
chris_on_tour2002
by chris_on_tour2002 » Sat Mar 19, 2011 2:15 am
is the shower fed from the main or the cold water storage tank? it could be a pressure problem, modern electric showers have a safety cut out should the pressure drop. could also be a faulty pressure sensor.
ItsBroken
by ItsBroken » Sat Mar 19, 2011 5:10 pm
Hi chris_on_tour2002
We have a combi unit, no water tank, so i believe its from the main water feed.
chris_on_tour2002
by chris_on_tour2002 » Thu Mar 24, 2011 11:58 pm
good - electric showers should always be mains feed anyway to avoid pressure drop and reduce the risk of scalding.
there is either a blockage in the pipe causing a drop in pressure look inside the shower, you may have to disconnect the feed pipe to find a gauze filter. this could be gunked up limiting the flow.
ISOLATE THE ELECTRICAL SUPPLY FIRST AT THE CONSUMER UNIT - not sufficient just to isolate at the pull cord even though it should be a double pole switch if the correct one has been fitted.
the only reason i can think of that it would just suddenly stop is if it senses a pressure drop. so it's either a blockage or a faulty sensor.
though it could also happen if someone turns a tap on elsewhere in the house whilst the shower is running - if the whole house is mains fed then another tap running will starve the shower causing a drop and the pressure sensor to kick in. eliminate this first by running the shower, wait til it is running hot then turn on another tap, preferably kitchen cold, and see what happens.
It is currently Sat Jan 11, 2025 10:48 am
