Polystyrene Coving Fire Risk
traffic
by traffic » Mon Mar 14, 2011 4:41 pm
I am currently decorating a nursery for the arrival of my son. I was about to fit some of the polystyrene coving around the room and somebody advised me not to due to it being a fire risk.
Can anybody advise me on if this is true or not cause its not something i have heard of.
JRS
by JRS » Mon Mar 14, 2011 6:27 pm
Yes all council houses have these removed when they become vacant. If you want cove thats light and easy to use i recommend super cove from BnQ and if you cand do the miters get the fitted corners pre cut things.
theshedman
by theshedman » Mon Mar 14, 2011 6:40 pm
Hi traffic, if you haven't got it yet then I would say not to bother. It never looks good and is not much cheaper or easier to put up than the proper plaster coving. If you do use it then yes it can be emulsioned over but nothing else should be put on it. Some paints can melt the stuff while others make it dangerous if you did have a fire. Personally I would never use it as I just don't like the stuff.
traffic
by traffic » Tue Mar 15, 2011 5:18 am
Thanks for the replys it is the super coved stuff from bandq i think that were using.(lost the label now) but it comes in room packs with the corners cut and everything
It is currently Sat Jan 25, 2025 2:06 pm
