FCU as light switch?
antiNa
by antiNa » Tue Mar 15, 2011 7:37 pm
The supply to the outdoor light at my property is a spur from the ceiling rose in the living room run to a switch and then to the light itself. The neutrals are joined with a connector behind the switch. No problems there but I'd like to have a means of isolating the light if anything goes wrong so I can work on it.
Is it allowable to just replace the light switch, at shoulder height, with a switched FCU and use that as the on/off switch instead? The FCU having proper terminals for all three core wires instead of the current nylon connector for the neutrals makes more sense to me.
Tis OK? Y or N?
Ant
collectors
by collectors » Wed Mar 16, 2011 12:44 pm
Yes! it is actually better as you will isolate both live & neutral. Pop a 3amp fuse in the spur.
chris_on_tour2002
by chris_on_tour2002 » Sat Mar 19, 2011 1:46 am
also better as you'd be fusing it down from 6Amp to 3Amp.
It is currently Thu Jan 16, 2025 12:57 am
