by welsh brickie »
Sat Mar 19, 2011 12:00 pm
Planning Permission first.
you will need to measure the walls and floor obviously.Go to your local builders merchants they should price it for you.
price for k18 plasterboard for walls and bags of drywall adhesive,thistle board finish plaster for ceiling and walls.
floor area you will need to raise the height to match inline with the house
so floor joists every 450mm centres I assume you will require 150mmx50mm joists .Kingspan or similar for the floor 50mm thick fitted inbetween joists
Tounge and groove flooring
insulation for ceiling 200mm thick rockwool or kingspan.plasterboard for ceiling
airbricks for ventilating the floor
bricks for blocking up garage door and price for window
there will be some things I have missed but that covers most of it.
