Insulating single brick walls.
sian3603
by sian3603 » Sat Mar 19, 2011 3:50 pm
I have a 2 bedroom semi detached house that has a single brick extension/utility room. At the minute it's used as a utility/store room, with the washing machine, tumble dryer and all sorts of other stuff that never gets used in there!
I want to convert it into a 3rd bedroom and was wandering how to insulate the walls and roof as it's only single brick. I'm not sure what the roof is, it's flat and has a felt outer covering.
It measures approx 8' high, 15' wide, 25' long. (The house is rented out and I live in a differant area, hence approx dimensions)
Any advice would be greatful please.
Thanks.
by stoneyboy » Sun Mar 20, 2011 7:27 pm
sian3603,
Roof - remove existing ceiling, add insulation leaving an air gap above, fit permanent ventilation for the gap, fit a new ceiling.
Walls - preferably fit insulation to the outside and then render/clad as required, this may need Planning Permission.
sam0010
by sam0010 » Tue Jun 21, 2011 11:27 am
Hi Sian 3603,
I work for Kingspan Direct. Another alternative to the wall insulation if you are wanting to insulate internally would be to use an insulated plasterboard fixed to a 25mm treated timber batten. Our recommendation is the Kooltherm K18 insulated plasterboard for solid walls. Other manufacturers may have some alternative options available for you as well.
It is currently Tue Nov 26, 2024 8:17 pm
