I wont explain the reasons but the Immersioan Heater has been on continually for a month or so, the only clue was scalding hot water in the taps, I have now figured that problem out and have normal hot water in the hot water system now.
My problem is that the thermostatic shower in my ensuite only gets luke warm, even at full temp. My question is this
could putting scalding hot water through it have damaged the thermostat in the shower causing this "not getting hot " problem?
or is it just coincidence that this has happened and its just scaled up inside and knackered?
thanks in advance
