SCREW HOLE
BJASAD
SCREW HOLE
by BJASAD » Wed Jun 20, 2007 10:37 am
A SCREW HAS PULLED OUT OF MY HARDWOOD WINDOW FRAME - WHAT IS THE BEST WAY OF FIXING IT - CAN I USE FILLER AND RE -SCREW -CAN ANYONE RECOMMEND A PRODUCT-THANKS
thedoctor
by thedoctor » Thu Jun 21, 2007 6:59 pm
You need a two part wood filler and make absolutely sure you get it right into the hole. See link below for filler. Its very often easier however to drill a larger (10mm) hole and glue in a dowel which can be bought from most DIY stores. Then cut the dowel off flush with the front of the frame.
http://www.awin1.com/pclick.php?p=79825 ... 071&m=1228
It is currently Thu Oct 31, 2024 8:24 pm
