Expansion Tank - hot water constantly running
6 posts   •   Page 1 of 1
Minder
by Minder » Mon Mar 28, 2011 3:32 pm
I have a gas fired aga boiler which runs my heating system. I have noticed over the last 2 weeks that there is warm water dribbling in to my expansion tank. Can anyone suggest the reason for this.
I think it is running constantly as it is a holiday cottage and I only get there the odd weekend.
Many thanks
by stoneyboy » Tue Mar 29, 2011 9:40 pm
Minder,
Either the pump needs turning down or you need to raise the height of the vent pipe.
Minder
by Minder » Thu Mar 31, 2011 12:30 pm
Stoneyboy,
Thank you for your reply, I am there this weekend and will have a look. The system has been in for about 15 years but just had it serviced before christmas. There was so much rubbish came out the radiators it was unbelieveable.
Are all pumps speed adjustable..?
Thanks,
Minder
lofc
expansion tank running.
by lofc » Thu Mar 31, 2011 9:24 pm
Yes, all heating circulators are adjustable. If your heating system is full of gunge it could do with being flushed out & a heating system cleanser added or something like a magnaclean (check out their website first). Both options will improve your boilers efficency.
Minder
by Minder » Fri Apr 01, 2011 8:35 am
My system was flushed out the end of last year....I am wondering if this has caused the pump to run more efficiently and causing the problem....Does that sound possible....?
Thanks..
by stoneyboy » Sat Apr 02, 2011 6:26 pm
Minder,
There's a good chance that whoever serviced the system turned up the pump - check this before doing anything else.
It is currently Tue Nov 26, 2024 3:40 am
