Have spent some time trying to research this online, hopefully someone can give me some ideas...
I got a load of slabs normal thickness say 30mm, I have a large area to pave in the garden, I have a load of reclaimed bricks too. My question is, can I cut the bricks into say quarters of around 30mm thick and then use these as paving. digging to different depths would be hard work so would like to avoid.
Another question is, can I cut the brick length ways in half to a thickness of around 30mm, keeping in mind that the bricks are frogged... would this make the bricks weak and lead to cracking when stood on?
Thanks in advance.
