painting dark over light colour
Tockwith358730
by Tockwith358730 » Thu Apr 07, 2011 4:24 pm
I have painted 2 coats of a darker matt paint over a pale silk colour in the bathroom and the pale colour is still coming through the dark colour through little cracks in the paint - what can i do to stop this? use a primer paint? use proper bathroom paint?
JRS
by JRS » Thu Apr 07, 2011 5:32 pm
Try another coat. if its a cheap matt it will be see through, and if its in a bathroom it wont last very long. Use a durable matt for bathrooms.
theshedman
by theshedman » Sat Apr 09, 2011 9:12 am
Hi, I agree with JRS on putting on another coat or sometimes maybe 2 more coats depending on make of paint. I always use Dulux as I find it covers better with less coats than cheap ones so costs less as you won't need so much of it and takes less time to do. Even then I have found that the Dulux ready made paints, ie off the shelf seem to be thicker than the colours made especially for you, the type they mix in store. Putting light over dark or the other way around always takes more coats than like for like. A bathroom paint is definately the best to use as it has got stuff in it to help keep mould and mildew to a minimum and it does work.
It is currently Fri Jan 10, 2025 3:52 pm
