Unused gas flue
the2ems
Unused gas flue
by the2ems » Thu Apr 07, 2011 10:20 pm
My daughter has just bought an oldish ex council house which has a small round flue under the front lounge window (outside). On the inside is one of those plastic slide open/shut vents. There is a 15mm blanked off pipe close to the inside vent, and now that I have stripped the wall paper it is apparent that there was probably a gas fire on the wall. The house now has gas fired central heating, with the boiler in the kitchen. There is also a pot bellied multi fuel stove in the lounge. As there is no longer a gas fire in the lounge, is it OK to brick up the vent?
Fluid
by Fluid » Fri Apr 08, 2011 1:29 pm
If you can, read the instructions for the stove and find out the ventilation req for it... there is nothing to stop you from bricking up the old flue and putting a new vent (if req'd) in a more pleasing position in the same room.
It is currently Sat Nov 30, 2024 7:37 am
