4inch blockwork wall
dan83
by dan83 » Mon Apr 11, 2011 1:13 am
I am planning to build a 4 inch blockwork wall aprox 1.5high x 7m long in the back garden. I am wondering if and were if needed i would need to put a movement joint and also supports in the wall. the wall is not load bearing
block wall
by welsh brickie » Mon Apr 11, 2011 11:51 am
you need pillars at each end of the wall and where the expansion joint is in the middle of the wall at 3.5metres,So 4 pillars in total
andy01
by andy01 » Wed Jun 08, 2011 9:09 pm
you could get away with three piers.
place the movement joint next to the central pier and use debonded wall ties at 225mm vertical centres
It is currently Fri Nov 15, 2024 1:09 pm
