What are the drawbacks of vinyl tiles?
mathewhogard
by mathewhogard » Mon Apr 11, 2011 8:38 pm
Hi Guys!!
I have been thinking to go for vinyl flooring?
So before finalizing the same want to know the Pros and cons of it so basically...What are the drawbacks of vinyl tiles? Can anybody will explore all?
Best Regards,
Mathew
chris_on_tour2002
by chris_on_tour2002 » Tue Apr 12, 2011 11:21 pm
drawbacks:
1) as the tiles are flexible and only a few mm thick your subfloor needs to be perfectly flat and smooth. and imperfections will stick out like a sore thumb and may affect adhesion, causing the edges of the tiles to peel back.
2) it's a messy business if you use the old tar-like adhesive they always used to use to lay vinyl. not sure if you still need to use that stuff though, F44 or F45 acrylic adhesive might do it. check mfr's recommendations.
3) they are a nightmare to remove when the time comes to change them.
4) a bit old-fashioned?
advantages:
1) quick and easy to lay
2) relatively cheap
3) tough and durable
4) easy to clean
pays your money, takes your choice.
It is currently Fri Jan 10, 2025 7:24 am
