concrete slab for summerhouse
olliejames
by olliejames » Thu Apr 14, 2011 12:31 pm
Hi there, my mate wants me to lay a concrete slab for summerhouse, its going to be 4 metres x 4 metres sq, what should be the depth of the hardcore and the depth of the concrete, how much material will i need thankyou hope you can help me
stokedan1
by stokedan1 » Fri Apr 15, 2011 7:46 pm
Whats the ground like? if ground is bad dig off till you reach clay, build back up with hardcore cap off with 100mm of type 1 MOT, then a 150mm conc slab, if ground is good no need for hardcore.
MOT at 100mm = 3.84 ton
conc at 150mm = 2.4 cubic metres
Hardcore if needed depends on how much you have to dig out
stokedan1
by stokedan1 » Fri Apr 15, 2011 7:57 pm
sorry mate forgot about visqueen on top of mot/under conc for damp protection
olliejames
by olliejames » Mon May 02, 2011 12:24 pm
stokedan1 wrote:sorry mate forgot about visqueen on top of mot/under conc for damp protection
Hi stokedan1 sorry for the delay in my reply thanks for the advise should be sound now cheers
It is currently Mon Dec 23, 2024 10:25 am
