I've ordered a new 12x8 shed to arrive in a few days. The shed will sit in an area, which is currently grass and can get quite wet when it's rainy. I've weighed up the base options but still not sure of the best approach, but I don't think a poured concrete base is an option.
I have 6 spare concrete blocks (currently used as doorsteps; 36"x10"x6"), which I was thinking of laying in the corners and centres to support a timber frame for the base.
A few questions...
Should I dig down a few inches, so that the blocks are set into the ground (on compacted soil / pea gravel?) and so that the timber is virtually level with the surrounding ground?
Should I also lay a weed barrier and cover with pea shingle / gravel?
Should I anchor the frame to the blocks and if so, how?
Should I use 2x6 or 2x4 for the frame?
Any response is welcome, even if it's just general mockery if I'm way off track so far!!!
Many thanks.
