Hi, just moving into a ~8 year old house (so I assume all the electrical wiring is up to spec) and have a question about double fixed wall sockets.
The room where I plan to have my home cinima setup and computer has two fixed double sockets, they are on opposite walls but I am unsure about current limits.
If I power on all the home cinima equipment together then the current could spike well above 13A, probably above 20, I have read that fixed double sockets are probably 20A limit but this raises some questions,
1 - What current limit are fixed double sockets (its not twice 13A obviously but some people claim 13A total and others 20A)?
2 - Are both double sockets in the room going to be on the same ring, i.e. is it 13A or 20A for both double sockets together?
Will the main circuit box trip if the current is exceeded? i.e. how do I know if I have gone too far - before the smoke alarm goes off...
Basically can I take both double sockets up to 20A or is this asking for trouble? If I cant then do I need to put some of the gear in a different room - will this even make any difference... I assume there is a 100A line comming into the house, humm
Thanks for any info!
