What bonding is required for standalone rig
fisha
by fisha » Fri Apr 22, 2011 4:59 pm
Hi i have built a standalone water rig for a college project. The rig is powered from a nearby socket and contains copperpiping and is built from unistrut. My question is what bonding would this rig require.
Thanks guys
by ericmark » Fri Apr 22, 2011 8:30 pm
In the main the earth provided from the plug is enough. However you do need to check this is connected. The normal method would be to use a PAT testing machine which passes a 25 amp current through the earth path to check there are no bad connections. The rig will be registered as an item on the appliance list and there will be a record of it being tested. Likely also a sticker to say it has been tested.
It is currently Wed Jan 15, 2025 10:45 pm
