Hi, whilst doing some landscaping I put the digger through the water main, 25mm MDPE. Turned off at street. No major issue went got some fittings and repaired. Turned water back on, went inside turned on tap, nothing, no water at all not even a trickle, went out turned water off at street split the new joint, turned water back on plenty of water, connected back up turned on water still nothing, am I missing something or is it likely mud has made its way up the pipe and blocked the stop cock.
Thanks in advance.
Gary.
